helpmepls321
Sep 13, 2018Aspirant
netgear x500 vpn
hi i need some help how can i change the vpn servers it still under hidemyass. ? any fixs
No idea I'm afraid.
But no clue why it should not be possible to have a generic OpenVPN client able to connect to various VPN providers, typically just by importing the OpenVPN config, or by importing an OpenVPN config plus the certificates required. No rocket science. - Netduma-FraserNetDuma PartnerVPN Hybrid solution isn't available yet which will allow you to use other VPN providers but once it is I will provide it to you.
- helpmepls321Aspirant
is there a way i can have the beta i like to test it
