GS3339
Sep 27, 2022Guide
Netgear Xr 1000 wifi problem
Hello, I have a big problem with my Router.. For example we watch TV at night youtube netflix etc... than close tv sleep and in the morning tv has no connection with wi fi?? Wtf is that? My moth...
Netduma-Fraser
Sep 28, 2022NetDuma Partner
Disable Smart Connect for WiFi and manually connect devices to 2.4 or 5GHz and see if that resolves the issue please
- FURRYe38Oct 02, 2022Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?How is Basic and Advanced wireless settings configured on the router?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Be sure wifi adapter drivers are up to date on the laptop.
Might try disabling AX and OFDMA on the router.
Set 40Mhz only co-existance.
