Bcon
Feb 24, 2019Aspirant
Netgear xr 500 router DISCONNECT ISSUES WITH XBOX 1X
My XR 500 router was doing fine since October when I bought it. The last few weeks I've been getting disconnect issues on a "daily" basis when I wasn't on my xbox or PC. I notice this when I'm inacti...
Netduma_Jack
Feb 25, 2019NetDuma Partner
Hi there - Microsoft and NETGEAR are working on finding a solution to this. One thing that I heard worked for some users is to put a switch between the router and the Xbox. So if you have a switch in your home, you could give this a try. No guarantee it will work though!
serpentdeceiver
Feb 25, 2019Aspirant
You've been saying this for a while now. After waiting month after month for this router to have its issues fixed, I think it's safe to say nobody is actually trying to fix anything. I am sure Microsoft and Netgear, together, could have come up with a solution faster than this if they really had competent people dedicated to the issue.
Netgear support can only ask you to reset the router every time and then turn all the features I bought the router for off. They read off a script and don't seem to actually know of this issue. Do you find it acceptable that the only solution, after all this time, is to turn features off on expensive, premium devices? We paid extra for something that actually does less than routers three times less expensive. We paid so much extra, and the only thing we got out of this was less. $300 for a buggy and mostly average router. Thanks.
