Fukarax3
Feb 22, 2021Follower
Netgear XR 500
Hello i have some problems with Warzone Geofilter, if i put a circle that is not used in game it say iam in my orginal country?? then i play my standart lobbies .. and the geo filter dont show me the ...
Netduma-Liam
Feb 23, 2021NetDuma Partner
Hey!
Geo-filter is designed to ensure you are connecting to the server(s) offering you the best connection, it isn't designed to change your geo-location.
For more information as to how you can optimise Geo-filter to ensure you're getting the best out of it, check out this guide on our knowlege base:
