ishrakimroze
Nov 01, 2021Aspirant
Netgear XR1000 - USB drive/Readyshare connectivity issue
Hi, I have a "seagate 2TB ultra touch portable" hard drive that I tried to connect to the XR1000 router to use the readySHARE functionality. However, the router is not detecting the drive connect...
ishrakimroze
Nov 02, 2021Aspirant
Thanks for responding, my drive is called a Seagate Ultra Touch Portable Drive. Model No:STHH1000402. Note product link below:
https://www.seagate.com/au/en/products/external-hard-drives/ultra-touch-external-drives/
I didn't see the XR1000 routwr in the link you shared, I checked the XR500 as the closes reference and didn't find this drive there unfortunately.
ishrakimroze
Model No - STHH1000402 ****
- Netduma-LiamNov 02, 2021NetDuma Partner
Thank you!
Does the HDD require any additional drivers be installed onto your PC for you to access it? If so, that won't work with ReadyShare, it needs to be completely plug-and-play as far as I'm aware.
What do you see when you go to enter \\readyshare into Windows Run?
