Bluelv702
May 27, 2022Aspirant
Netgear XR1000 Gaming Router only reading 20hz channels nothing else
Hello Fam! I bought this "WiFi 6" router to get the top speeds, I've owned it for about a little over 3 months now, and ever since I've been trying to see how to get this issue fixed but have bee...
Netduma-Fraser
May 28, 2022NetDuma Partner
We've actually seen that if you reduce the mode down one level for 5GHz people can get better results as 160hz doesn't seem to work well for all devices, give that a try.
- Bluelv702Aug 19, 2022Aspirant
I've tried that but still only shows me 20MHz channel.
- Netduma-FraserAug 21, 2022NetDuma PartnerThe different widths use a lot of the same channels, also depending on your region some channels may not be shown due to your local restrictions. The mode is essentially your width options, Up to 4800 Mbps being 160
