Bluelv702
May 27, 2022Aspirant
Netgear XR1000 Gaming Router only reading 20hz channels nothing else
Hello Fam! I bought this "WiFi 6" router to get the top speeds, I've owned it for about a little over 3 months now, and ever since I've been trying to see how to get this issue fixed but have bee...
May 27, 2022Guru - Experienced User
when you have it set to "up to 4800mbps" its running in 160hz wide channels. it has to overlap quite a few channels to work in 160hz wide.
what makes you think its only in 20hz wide?
Bluelv702
Aug 19, 2022Aspirant
When running Wifi Analyzer it shows me the channels and 20/40/80/160MHz. When I go to my router to change the Channel it only shows 20MHz Channels, not even 40MHz.
