SuicideSquad420
Apr 07, 2022Apprentice
netgear xr1000 gaming router
so i updated the xr1000 to the newest firmware in for some reason i keep getting a error code Uncaught TypeError: $(...)[0].getApp is not a function everytime i log into the router in sometimes it ta...
Netduma-Fraser
Apr 07, 2022NetDuma Partner
If you haven't already it is recommended to do a factory reset after an update to ensure no issues carry over from the previous version, I suspect if you do so the issue will be resolved.
- SuicideSquad420Apr 08, 2022Apprentice
so i did what u said in still getting the same error code Uncaught TypeError: $(...)[0].getApp in it still taking forever to load even after reset you all gotta loook into it. with this new update.
- Netduma-LiamApr 08, 2022NetDuma Partner
Could you please clear your browsers cache now and that should then clear it for you.
As above, please factory reset the XR1000 after installing the firmware and clear your browsers cache.
thank you did the reset still was doing it cleared my cache now its gone thanks for the help.
- SKWildCatApr 08, 2022Aspirant
Uncaught TypeError: $(...)[0].getApp is not a function, Problem I have a problem what to do
- SuicideSquad420Apr 16, 2022Apprentice
so now im getting a error code when trying to log into the router now starting to be weird ever since i updated to the newest update i had have problems with this router the error im getting now tho is haserl CGI Error
Failed to readline from 'config get DumaOS_Theme_Version'
ok sooo my router keeps factory reseting itsself after the new update to why??????? i need a fix asap. i mean this update broke my router.
- Netduma-FraserApr 16, 2022NetDuma PartnerThat error should be resolved by a reboot. How can you tell it's doing a reset - is the wizard showing up every time you access? How often is it trying to reset? When you did the reset previously did you do it via the interface or hardware?
i did the reset from hardware the back of the router this update broke my router now even when i reset the router it just keeps factory reseting its self.
- SuicideSquad420Jun 21, 2022Apprentice
im telll you right now this new update broke my router.... i tried everything u said in stilll doing the same stuff with it. tried reseting etc noting is helping it it happen right after i updated in has been happening ever since.
- Netduma-FraserJun 21, 2022NetDuma PartnerIt's giving you the same errors still or you're experiencing other issues as well? May be best to downgrade back to a version that was more stable for you until a new update is available. For a replacement you would have to make a ticket with Netgear directly, it's not something we can advise on.
- SuicideSquad420Sep 02, 2022Apprentice
man im be honest don't even try to reset this router its goin to keep happening. i been dealing with it for months noting changed with it. so i just gave on the router for now till i can see if they fix it with an update if that dosn't happen im just goin to take my 300 dollar loss in move on from it like i did months ago. in i love netgear in netduma routers but everything they try in tell you to do don't work at all man. i hope it gets fixed in the next update we need it asap.
