SuicideSquad420
Apr 07, 2022Apprentice
netgear xr1000 gaming router
so i updated the xr1000 to the newest firmware in for some reason i keep getting a error code Uncaught TypeError: $(...)[0].getApp is not a function everytime i log into the router in sometimes it ta...
Netduma-Fraser
Apr 07, 2022NetDuma Partner
If you haven't already it is recommended to do a factory reset after an update to ensure no issues carry over from the previous version, I suspect if you do so the issue will be resolved.
SKWildCat
Apr 08, 2022Aspirant
Uncaught TypeError: $(...)[0].getApp is not a function, Problem I have a problem what to do
