SuicideSquad420
Apr 07, 2022Apprentice
netgear xr1000 gaming router
so i updated the xr1000 to the newest firmware in for some reason i keep getting a error code Uncaught TypeError: $(...)[0].getApp is not a function everytime i log into the router in sometimes it ta...
SuicideSquad420
Apr 08, 2022Apprentice
so i did what u said in still getting the same error code Uncaught TypeError: $(...)[0].getApp in it still taking forever to load even after reset you all gotta loook into it. with this new update.
Netduma-Liam
Apr 08, 2022NetDuma Partner
Could you please clear your browsers cache now and that should then clear it for you.
As above, please factory reset the XR1000 after installing the firmware and clear your browsers cache.
- SuicideSquad420Apr 08, 2022Apprentice
thank you did the reset still was doing it cleared my cache now its gone thanks for the help.
