SuicideSquad420
Apr 07, 2022Apprentice
netgear xr1000 gaming router
so i updated the xr1000 to the newest firmware in for some reason i keep getting a error code Uncaught TypeError: $(...)[0].getApp is not a function everytime i log into the router in sometimes it ta...
Netduma-Fraser
Apr 07, 2022NetDuma Partner
If you haven't already it is recommended to do a factory reset after an update to ensure no issues carry over from the previous version, I suspect if you do so the issue will be resolved.
SuicideSquad420
Apr 16, 2022Apprentice
so now im getting a error code when trying to log into the router now starting to be weird ever since i updated to the newest update i had have problems with this router the error im getting now tho is haserl CGI Error
Failed to readline from 'config get DumaOS_Theme_Version'
