Freek245
Dec 19, 2022Aspirant
Netgear xr1000 high ping under load
I recently purchased the xr1000 gaming router because I thought that was the issue I was having with my connection while playing games on my pc was my old router. While this router has a TON more f...
- Dec 22, 2022Yes a lot better, you were spiking into the 100's before, now it's spiking between 10-20ms so you should notice a big difference. Now just fine tune QoS as much as possible and you'll be good to go.
Freek245
Dec 21, 2022Aspirant
sorry had to make another reply i can only post one pic at a time, which you guys prob already know lol, thanks.
Netduma-Fraser
Dec 22, 2022NetDuma Partner
