zizuo
Apr 29, 2022Aspirant
netgear xr1000 interface access problems
Hi I have a Netgear XR1000 gaming router. since I have it I had so many issues like: 1- 1st setup\ Geofilter is not working and I found a solution here advice me to do a hard rest which I d...
zizuo
hey guru
thank you for fast reply
1- I mentioned the website I use to login which is http://www.routerlogin.net/desktop/index.html#com.netdumasoftware.systeminfo
2- I use the latest firmware which is XR1000-V1.0.0.64_1.0.49
3- yes I did and now I down grade my firmware version to XR1000-V1.0.0.58_1.0.44 and did a hard rest and set it up again seem to me same issue.
4- thank you so much for your help
I forgot to mention I always get a message in router page says ( you are no longer connected to your router. if your router is rebooting then keep this page open as it will automatically reconnect to the router interface when the reboot is complete. otherwise please check your connection e.g. you connected to the correct router ) while I'm not rebooting the router
also I would like to mention that I'm using pppoe bridge connection ( maybe this is Couse the problem )
Netduma-Fraser
Apr 29, 2022NetDuma Partner
Can you access using http://192.168.1.1 instead at all and see if that allows you to stay on the interface without error?
- zizuoMay 02, 2022Aspirant
i tried to get access using every passable website for the router
the only one working is http://routerlogin.net/adv_index.htm which is for basic setting of the router without DUMAOS
sometimes it's work but I find issues like the geofilter is not working or QOS is not working
I have done every passable solution I found in here but still not working probably
- Netduma-LiamMay 03, 2022NetDuma Partner
OK in that case could you please downgrade to the previous firmware as you mentioned and see if that resolves the issue?
Let us know if it does and we can debug it further.
- zizuoMay 03, 2022Aspirant
I've already downgrade my firmware and did a hard rest then upgrade it again but still the same issue
