Fab5
Feb 10, 2022Initiate
Netgear XR1000 internet flashing red and green
I’m having issues with the internet LED flashing red and green. I have reset it and it stays solid white for several hours then returns to the flashing red/green. I am using the latest firmware 1.0.0....
Netduma-Fraser
Feb 10, 2022NetDuma Partner
I'd suggest reupgrading the firmware using the TFTP method, this bypasses the boot process and any issues there then once done do a factory reset for the freshest install possible: https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Fab5
Would this need to be done if the system is running fine? Even with the blinking internet LED I still have good use of the internet both connection and upload and download speed
- Netduma-FraserFeb 11, 2022NetDuma PartnerAh in that case don't worry about it, you can see what the colors mean here: https://kb.netgear.com/24244/Understanding-NETGEAR-LED-Symbols
