SIERRA117
Sep 18, 2022Tutor
Netgear XR1000 internet flashing red and green
My router is doing this and I’m just curious as to what this means. I came across another thread saying not to worry about if it’s working fine. Which it is working fine, I would just like to know wha...
- Sep 22, 2022So far so good, 2 nights with no red and green. So I guess I’ll chalk it up to the firmware updates without factory resets for now. Appreciate the help.
Netduma-Fraser
Sep 19, 2022NetDuma Partner
Could be micro disconnections perhaps, try changing the ethernet cable connecting the router to the modem and see if that resolves the issues.
- SIERRA117Sep 19, 2022TutorThanks for the replay. I’ll try this later when I get home . I mean an ethernet cable is a cheap enough hip shot. I’m just not fully convinced that’s the problem. I’ve searched this before and vaguely recall seeing something somewhere about the router configuring or something? Not sure exactly what it meant back when I read it and I couldn’t find it when I tried looking for it again.
- Netduma-FraserSep 19, 2022NetDuma PartnerThat would only happen if it's rebooting or going through a reset and you would notice either of those things happening. When it happens you could grab the log from the System Information page and I can see if there is anything referencing it there.
- SIERRA117Sep 19, 2022TutorWell tonight no blinking. Imagine that…. It’s pretty intermittent but I’ve now seen it often enough I’d like to know what exactly it is…… I’ll try and catch it one of these times.
