SIERRA117
Sep 18, 2022Tutor
Netgear XR1000 internet flashing red and green
My router is doing this and I’m just curious as to what this means. I came across another thread saying not to worry about if it’s working fine. Which it is working fine, I would just like to know wha...
- Sep 22, 2022So far so good, 2 nights with no red and green. So I guess I’ll chalk it up to the firmware updates without factory resets for now. Appreciate the help.
SIERRA117
Sep 19, 2022Tutor
Thanks for the replay. I’ll try this later when I get home . I mean an ethernet cable is a cheap enough hip shot. I’m just not fully convinced that’s the problem. I’ve searched this before and vaguely recall seeing something somewhere about the router configuring or something? Not sure exactly what it meant back when I read it and I couldn’t find it when I tried looking for it again.
Netduma-Fraser
Sep 19, 2022NetDuma Partner
That would only happen if it's rebooting or going through a reset and you would notice either of those things happening. When it happens you could grab the log from the System Information page and I can see if there is anything referencing it there.
- SIERRA117Sep 19, 2022TutorWell tonight no blinking. Imagine that…. It’s pretty intermittent but I’ve now seen it often enough I’d like to know what exactly it is…… I’ll try and catch it one of these times.
- SIERRA117Sep 21, 2022TutorAlright, so I hadn’t logged into the router in a long time. Nothing in DumaOS was working at all. So did a factory reset and got all the Rapps working again. I know router has had several updates without any factory resets. So maybe that was the problem?
- Netduma-FraserSep 22, 2022NetDuma PartnerQuite possibly, we always recommend a factory reset after an update to remove remnants from previous versions that could cause issues. Have the lights gone back to normal now?
- SIERRA117Sep 22, 2022TutorSo far so good, 2 nights with no red and green. So I guess I’ll chalk it up to the firmware updates without factory resets for now. Appreciate the help.
