SIERRA117
Sep 18, 2022Tutor
Netgear XR1000 internet flashing red and green
My router is doing this and I’m just curious as to what this means. I came across another thread saying not to worry about if it’s working fine. Which it is working fine, I would just like to know wha...
- Sep 22, 2022So far so good, 2 nights with no red and green. So I guess I’ll chalk it up to the firmware updates without factory resets for now. Appreciate the help.
SIERRA117
Sep 21, 2022Tutor
Alright, so I hadn’t logged into the router in a long time. Nothing in DumaOS was working at all. So did a factory reset and got all the Rapps working again. I know router has had several updates without any factory resets. So maybe that was the problem?
Netduma-Fraser
Sep 22, 2022NetDuma Partner
Quite possibly, we always recommend a factory reset after an update to remove remnants from previous versions that could cause issues. Have the lights gone back to normal now?
- SIERRA117Sep 22, 2022TutorSo far so good, 2 nights with no red and green. So I guess I’ll chalk it up to the firmware updates without factory resets for now. Appreciate the help.
