Mohammed1981
Apr 15, 2023Tutor
netgear XR1000 is not getting full speed in benchmark
Hello,
netgear XR1000 is not taking full speed internet from my modem, but when I do test speed on okla, it's shown that my speed is fine thru okla but not thru router benchmark
- Apr 17, 2023Take the Nokia out of bridge mode and put the XR WAN IP (found on the System Information page) in its DMZ instead and remove PPPoE/VLAN from the XR then it will work better. I'd suggest having a look through our optimal settings guides to help you get setup further as well: https://support.netduma.com/en/support/solutions/folders/16000090646
Mohammed1981
Apr 15, 2023Tutor
this my speed thru Ookla
Netduma-Fraser
Apr 16, 2023NetDuma Partner
As long as you're getting the correct speeds on Ookla then the router won't be limiting you. For Benchmark it uses a different speed test site so it will depend what servers it's using for the test so sometimes it can be lower than you expect. We're working on improving that.
