Mohammed1981
Apr 15, 2023Tutor
netgear XR1000 is not getting full speed in benchmark
Hello,
netgear XR1000 is not taking full speed internet from my modem, but when I do test speed on okla, it's shown that my speed is fine thru okla but not thru router benchmark
- Apr 17, 2023Take the Nokia out of bridge mode and put the XR WAN IP (found on the System Information page) in its DMZ instead and remove PPPoE/VLAN from the XR then it will work better. I'd suggest having a look through our optimal settings guides to help you get setup further as well: https://support.netduma.com/en/support/solutions/folders/16000090646
Mohammed1981
Apr 17, 2023Tutor
Hello and thanks for your reply
can you please walk thru with me and see if my setting are correct? cuz I'm not sure if I did it the right way
I can provide you some info about my setup:
ISP/ STC
internet /Fiber 1000↓/600↑
modem / nokia g-240w-c router in bridge mode for all port, so this router now is just passing the signal to netgear XR1000
In the router netgear XR1000, Internet Setup (Internet connection require loging"PPPoE" enabled for both Ipv4 & ipv6
also I had to enable Vlan tag
Netduma-Fraser
Apr 17, 2023NetDuma Partner
- Mohammed1981Apr 17, 2023Tutor
thank you, I will try to do that and compare between them
