Sascha45
Oct 26, 2022Tutor
NETGEAR XR1000 Just goes to password reset page
Hi, When I type in my router IP is just get the below message. If I fill all this out and continue I still don't get to the dashboard. Have reset the router countless times. I have tried Ch...
michaelkenward
Oct 27, 2022Guru - Experienced User
Sascha45 wrote:
Hi,
What "router IP" is that?
What modem/gateway/ONT connects your router to the Internet?
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Gaming routers have their own DumaOS operating system that is nothing like the one on Netgear's standard routers.
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
