Sascha45
Oct 26, 2022Tutor
NETGEAR XR1000 Just goes to password reset page
Hi, When I type in my router IP is just get the below message. If I fill all this out and continue I still don't get to the dashboard. Have reset the router countless times. I have tried Ch...
Netduma-Fraser
Oct 27, 2022NetDuma Partner
Good advice above, do let us know how you get on!
- Sascha45Oct 27, 2022TutorHi all, thanks for the reply's
It seems that if you click "exit" instead of "next" when you enter your new passwords and security questions, it works and you get to the dashboard. Seems like a simple little bug that could be easily fixed... Not looking at anyone... Netgear... This issue is solved, at least for me.- FURRYe38Oct 27, 2022Guru - Experienced User
So did you enter in new PW and security questions or did you skip this?
I was able to enter in new PW and security questions when I set up my XR1000.- Sascha45Oct 28, 2022TutorI had to enter new password and SCQ but previously I was clicking on next which would get me into a loop of entering passwords and scqs. Clicking exit instead worked.
