TypicalSwab
Feb 21, 2023Aspirant
NETGEAR XR1000; Location
Hi, I've recently moved in to another Property (8 days here) and have connected my XR1000 to the existing Modem/ISP here. If I use Google Maps to identify my location on my PC, it shows me a p...
TypicalSwab
Thanks for getting back to me.
I've just tried this and no, the behaviour doesn't apply if connected directly to the ISP's router.
Netduma-Fraser
Feb 21, 2023NetDuma Partner
Have you got your PC added to the Geo-Filter?
- TypicalSwabFeb 21, 2023Aspirant
No I do not.
- Netduma-FraserFeb 21, 2023NetDuma PartnerIf you type my location into Google search engine does it show correctly? Do it connected direct to the modem as well, do you get a different result?
