Vauxy
Jan 08, 2022Aspirant
Netgear xr1000 traffic controller netduma os
I have reset my Xr 1000 gaming router and my traffic rules have disappeared even though they are still running on the right hand side. I can not delete nor edit my rules. I use these to limit my chil...
Vauxy
Jan 11, 2022Aspirant
I reset through the reset button on the back of the router. Google chrome was recently updated on my computer would this cause an issue? Yes the panels on the right side are live.
Thanks for your response
Netduma-Liam
Jan 12, 2022NetDuma Partner
OK, and were you prompted to complete the initial setup again after resetting the XR1000?
I don't think the browser update would've caused an issue, though it might be best to clear your cache after the update and reset of the XR1000 as that can cause issues occasionally.
- VauxyJan 12, 2022AspirantYes I ran the full set up as you would when unpacking it from the box.
I’ll try clearing the cache.
