mr_nguyen
Jul 28, 2022Aspirant
Netgear XR1000 uPnP does not work with new firmware update
Hi,
I've updated my router (XR1000) to the latest firmware and I can not seem to get uPnP to work.
- DMZ is turned off
- NAT is Open
- uPnP is turned on
Can anyone assist?
Many thanks in advance.
- Netduma-FraserNetDuma PartnerAs you've set NAT to Open you should have any issues with ports or NAT, by UPnP not working are you referring to no entries in the table or you're having port issues?
- mr_nguyenAspirant
Do you mean that I should NOT have any issues with NAT being Open?
yes, I have no active entries in uPnP table.
- Netduma-LiamNetDuma Partner
Yeah, you should not see any NAT issues in game for example with this configuration.
How are you testing UPnP? Are you actively playing a game for example, then monitoring UPnP to see if any entries appear?
