Detanye's avatar
Detanye
Follower
Mar 19, 2026
Netgear XR1000v2 constant DNS issues
Hey all,
As the title suggests i am having constant networking issues where i am unable to connect to any websites for several minutes that occur multiple times a day. I also have a forum going on Netduma forum and so far with have.
Manually changed my DNS to google.
Changed my DHCP settings to create after .50 and have given all my devices a static address between .2 and .49.
I am still getting these issues with these changes, unsure what else i can do.
Has anyone else had this issue and managed to fix it?
  • Currently wondering if this could be similar to a V1 issue where if the OpenVPN server is enabled, it causes DNS issues, especially if any dynamic DNS service settings are also in use.
    The firmware 1.0.2.86 bug in the V1 may be the same on the V2. Hopefully there will be a firmware update soon, fixing it.
  • StephenB's avatar
    Are your browsers set to use the OS DNS (which comes from the XR1000)?  Or are they set to use DoH?
    If they are using the OS DNS, you should try changing that and see if it makes any difference.  If it doesn't, then that rules out DNS.
    You might also try running some long-duration ping test, (pinging 8.8.8.8 ) and see if how often that fails to get a response.
  • plemans's avatar
    What modem/gateway are you connected to?
    Are you using IPv6? if so, disable it.
    Who's your ISP? I know xfinity has had ipv6 issues for a while (from my own experience)
