chedyus
May 27, 2020Tutor
Netgear XR300 Geo Filter
Hi everyone, so i just purchased an netgear xr300 router and i just can t use the geo filter setting, is not working for me and i don t know what else to do i tried everything, even the filtering mod...
- May 27, 2020We need to update the Source Engine service so this is a workaround, we'll have it sorted for the next firmware.
Netduma-Fraser
May 27, 2020NetDuma Partner
Remove the device from the Geo-Filter and then change your PC to an Xbox or PlayStation in the Device Manager and then re-add it to the Geo-Filter, it should work then.
chedyus
May 27, 2020Tutor
it does work like that, thank you so much... it is a bug?
- Netduma-FraserMay 27, 2020NetDuma PartnerWe need to update the Source Engine service so this is a workaround, we'll have it sorted for the next firmware.
