Saud_Alsaif149's avatar
Apr 15, 2020
NetGear Xr300 in Saudi Arabia
Does NetGear Xr300 or higher works in Saudi Arabia? Am curios, I really don’t enjoy gaming because my latency is horrible (125ping) it’s ridiculous.
I would like to read your recommendations of which router is the best for gaming console.
1 Reply
  • Yes it would work in SA but keep in mind that it also depends where the closest servers are to you for the game you're playing. If they are far away then you'll still have a higher ping than if there was a server in your country. It is all about optimizing your connection the best you can on your end.
