S_P_E_C_I_A_L
Feb 12, 2022Aspirant
Netgear XR300 Wireless WAN
Hi, I bought a XR300 pro router and i wonder what i must do to put it into Wireless WAN mode, that is to say i want it to connect to an allready existing WLAN and use the existing WLAN as WAN por...
Netduma-Fraser
Mar 05, 2022NetDuma Partner
The point of the router is to get you the best connection possible so by using WiFi to get the router internet would be going against that
