Lukejenks1201
Jun 13, 2021Tutor
Netgear XR500 and Virgin Superhub 3 issues
Hello, Hopefully someone can help, I’ve done lots of searching online and can’t seem to sort my issue out. I have had my XR500 working perfectly with my superhub 3 for over a year until yesterda...
- Jun 15, 2021You take the WAN IP from the XR System Information page and put it in the VM DMZ which can be found in Security settings I believe.
Netduma-Liam
Jun 14, 2021NetDuma Partner
Are you able to access the XR500s interface from your web browser now?
VM modem mode can be a little funny sometimes so we typically suggest disabling it's Wi-Fi instead and put the XR500 WAN IP in the VM DMZ.
You can find the XR500s WAN IP in the System information panel in the DumaOS interface.
- Lukejenks1201Jun 14, 2021TutorI will try this, so do I put the router back into router mode?
- Netduma-LiamJun 15, 2021NetDuma Partner
Yes, please have both the VM Hub and the XR500 in router mode for this and let me know how you get on.
- Lukejenks1201Jun 15, 2021TutorI tried to do this but something doesn’t seem to right, I’m going to reset the XR500 as I think I changed something the other day and not too sure what.
Where do I put the ip from the XR500 in the hub settings?
