Lukejenks1201
Jun 13, 2021Tutor
Netgear XR500 and Virgin Superhub 3 issues
Hello, Hopefully someone can help, I’ve done lots of searching online and can’t seem to sort my issue out. I have had my XR500 working perfectly with my superhub 3 for over a year until yesterda...
- Jun 15, 2021You take the WAN IP from the XR System Information page and put it in the VM DMZ which can be found in Security settings I believe.
Netduma-Liam
Jun 14, 2021NetDuma Partner
Are you able to access the XR500s interface from your web browser now?
VM modem mode can be a little funny sometimes so we typically suggest disabling it's Wi-Fi instead and put the XR500 WAN IP in the VM DMZ.
You can find the XR500s WAN IP in the System information panel in the DumaOS interface.
Lukejenks1201
Jun 14, 2021Tutor
I will try this, so do I put the router back into router mode?
- Netduma-LiamJun 15, 2021NetDuma Partner
Yes, please have both the VM Hub and the XR500 in router mode for this and let me know how you get on.
- Lukejenks1201Jun 15, 2021TutorI tried to do this but something doesn’t seem to right, I’m going to reset the XR500 as I think I changed something the other day and not too sure what.
Where do I put the ip from the XR500 in the hub settings?- Netduma-FraserJun 15, 2021NetDuma PartnerYou take the WAN IP from the XR System Information page and put it in the VM DMZ which can be found in Security settings I believe.
