Lukejenks1201's avatar
Jun 13, 2021
Netgear XR500 and Virgin Superhub 3 issues
Hello, Hopefully someone can help, I’ve done lots of searching online and can’t seem to sort my issue out. I have had my XR500 working perfectly with my superhub 3 for over a year until yesterda...
  • Netduma-Fraser's avatar
    Netduma-Fraser
    Jun 15, 2021
    You take the WAN IP from the XR System Information page and put it in the VM DMZ which can be found in Security settings I believe.
