Gkontos10
Oct 23, 2019Aspirant
Netgear Xr500 cant get full speed
Hey guys I finally got a used XR500 After a factory reset i manage to make it work... But i face a huge problem... I cant get full speeds on XR500 but i did on through my modem.. (my provider modem...
Oct 23, 2019Guru - Experienced User
Under QoS, does the speed for DOWN show 138Mbps?
What happens if you disable QoS?
- Netduma-FraserOct 23, 2019NetDuma PartnerAfter going through the setup wizard did you do a speed test and see if you got full speeds or was it only after a few settings you noticed the issue? Have you tried with WiFi as well?
- Gkontos10Oct 23, 2019AspirantAt the wizard it runs a speed test by it self and it show 138 down, like the speed i got from modem...
I run a speed test after wizard and set up finish and i got 76 down..
But i didn't connect anything i just finished the set up...
At QOS i set it to 120 down and 7 up as the package i paid...- Netduma-FraserOct 23, 2019NetDuma PartnerAre you using a different ethernet cable from the PC you're testing on than you did when you test direct to the modem? Does WiFi give you the same slower speeds?
