Gkontos10
Oct 23, 2019Aspirant
Netgear Xr500 cant get full speed
Hey guys I finally got a used XR500 After a factory reset i manage to make it work... But i face a huge problem... I cant get full speeds on XR500 but i did on through my modem.. (my provider modem...
Gkontos10
At the wizard it runs a speed test by it self and it show 138 down, like the speed i got from modem...
I run a speed test after wizard and set up finish and i got 76 down..
But i didn't connect anything i just finished the set up...
At QOS i set it to 120 down and 7 up as the package i paid...
Netduma-Fraser
Oct 23, 2019NetDuma Partner
Are you using a different ethernet cable from the PC you're testing on than you did when you test direct to the modem? Does WiFi give you the same slower speeds?
- Gkontos10Oct 23, 2019AspirantI made new tests
ARRIS modem 116 down
Normal at XR500 73down
QoS disable 116down
Antibufferbloat Never - QoS enable 73down
VPN disable - QoS enable 81 second teat 72 down
So it seems QoS is limit my speed, what i have to do now??- Netduma-FraserOct 23, 2019NetDuma PartnerLet's keep all support related to this issue in this topic https://forum.netduma.com/topic/29625-cant-get-full-speeds-on-xr500/ please as you've got it in three different places so it's hard to keep track of what has been suggested and tried.
- Gkontos10Oct 23, 2019AspirantOk
