droesw
Jan 20, 2021Guide
Netgear XR500 Devices not being able to connect randomly
I recall a few weeks or so ago my XR500 router updated to firmware V2.3.2.66. I don't for sure know if this problem started after the update or before, but it was around the time. The issue is that a...
droesw
Jan 20, 2021Guide
It does happen after the reboot but not immediately after. I wanna say it’s happened about 4 times over the past 3 weeks, so usually when I reboot it works fine for 5 days or so but just randomly stops working normally at times. And yes, we’re using smart connect but we’ve never had this type of problem using it before. And the problem was happening on my roommates pc also, which is connected with ethernet
Netduma-Fraser
Jan 20, 2021NetDuma Partner
What is your exact physical setup? What is the model of your modem/router?
- droeswFeb 01, 2021Guide
My router is my netgear XR500 router, and the modem is an Arris TM1602A which I was given from my ISP Spectrum. When the problem occurs, I can't get any devices that weren't already connected to the router to reconnect, so I'll go to try and connect to the router and type in the password if prompted, but then it just takes awhile to attempt to connect to the router and eventually fails to connect, so I think it's safe to say that it's a router issue instead of a modem problem. And the issue just happened again 2 days ago, but I just rebooted the router again when the problem occured and it's been fine since then.
- Netduma-LiamFeb 02, 2021NetDuma Partner
Thanks for this information, could you try accessing the modem's interface and give the XR a static IP address?
- droeswFeb 10, 2021Guide
I did some research and found out that there's no real way to access these modems from spectrum. The problem just happened again today as my roommates began complaining they couldn't connect to the router again, and I tried to load the routers page to reboot it again but got this R App is not loaded yet message (attached a picture) and this pop up message continues after turning the router off and back on, so I guess this problem hadn't been fixed by the previous update either. Any other ideas, maybe installing an old firmware( I don't believe this problem with people connecting was happening with the previous firmware before the recent update but I'm not positive on that)?
