Stevecook
Oct 23, 2018Apprentice
Netgear xr500 doesn't detect internet to install
I'm trying to install the xr500 but when I go to router login and hit install it say I'm not connected to internet but if I hook my laptop up directly to mode which is netgear cm1000 the laptop. Conne...
Oct 23, 2018Guru - Experienced User
Power OFF both CM and XR. Power ON the CM modem first and let it sync. Power ON the XR router and walk thru the setup wizard with a wired PC connected to the XR router.
Be sure to use a good quality LAN cable between the modem and router.
Stevecook
I tried that it doesn't detect internet
