Stevecook
Oct 23, 2018Apprentice
Netgear xr500 doesn't detect internet to install
I'm trying to install the xr500 but when I go to router login and hit install it say I'm not connected to internet but if I hook my laptop up directly to mode which is netgear cm1000 the laptop. Conne...
Netduma-Fraser
Oct 23, 2018NetDuma Partner
It may be because they both default to the same IP address, if thats not the case you should definitely be able to access it via the default LAN IP which is 192.168.1.1 to complete setup
Oct 24, 2018Guru - Experienced User
The CM doesn't have a router thus it won't have a 192.168.1.1 address. The Address should be 192.168.100.1. Mine is.
Try swapping out LAN cabling between the CM and XR.
- Netduma_JackOct 24, 2018NetDuma Partner
Worst case, factory reset the XR500. Starting afresh will let the router auto handle the internet setup, which should hopefully fix your problem.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
- StevecookOct 25, 2018ApprenticeJack I finally got it to connect but something going on where I play cod and the router is not letting me connect to dedicated server. It's not even showing dedicated servers near me but I pull up the dedicated server map and it shows there are supposed to be. It's like the router not ping the dedicated server. It's connecting me to peer servers. It doesn't change if in spectating mode or filtering mode.
- Netduma_JackOct 25, 2018NetDuma Partner
Hi Steve - set your filter to a range you like. 1000km - 2000km is good
Then hard reset your console. Should be ok after this.
