Mr_Clow
Oct 25, 2020Tutor
netgear xr500 firmware 2.3.2.66
Last week I updated to new firmware 2.3.2.66. After that, I keep getting a network connectivity issue; my net keeps getting disconnected and reconnected, and the speed keeps dropping. After this issu...
Netduma-Fraser
Oct 25, 2020NetDuma Partner
Please try the 3.0 beta and then do a factory reset to start fresh and see if it continues. https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/bd-p/en-home-beta-npg-duma
Mr_Clow
Oct 25, 2020Tutor
I updated to new firmware still the connection is unstable keep getting connection issues
- Netduma-FraserOct 26, 2020NetDuma PartnerDid you do a reset after upgrading? Is it only WiFi or wired devices that are affected?
- Mr_ClowOct 26, 2020Tutor
Yeah, I factory reset after upgrading and connectivity issues happening in both wired and wifi.
- Netduma-FraserOct 26, 2020NetDuma PartnerGive your devices a reserved LAN IP in LAN Settings and see if that helps please.
