Mr_Clow
Oct 25, 2020Tutor
netgear xr500 firmware 2.3.2.66
Last week I updated to new firmware 2.3.2.66. After that, I keep getting a network connectivity issue; my net keeps getting disconnected and reconnected, and the speed keeps dropping. After this issu...
Mr_Clow
Oct 25, 2020Tutor
I updated to new firmware still the connection is unstable keep getting connection issues
Netduma-Fraser
Oct 26, 2020NetDuma Partner
Did you do a reset after upgrading? Is it only WiFi or wired devices that are affected?
- Mr_ClowOct 26, 2020Tutor
Yeah, I factory reset after upgrading and connectivity issues happening in both wired and wifi.
- Netduma-FraserOct 26, 2020NetDuma PartnerGive your devices a reserved LAN IP in LAN Settings and see if that helps please.
- Mr_ClowOct 27, 2020Tutor
The connection is still unstable from my Netgear router losing a lot of speed and getting higher ping in speedtest.net
