Mr_Clow
Oct 25, 2020Tutor
netgear xr500 firmware 2.3.2.66
Last week I updated to new firmware 2.3.2.66. After that, I keep getting a network connectivity issue; my net keeps getting disconnected and reconnected, and the speed keeps dropping. After this issu...
Netduma-Fraser
Oct 27, 2020NetDuma Partner
If you disable QoS fully in the Anti-Bufferbloat/Congestion Control 3 line option menu do you receive full speeds then?
Mr_Clow
Oct 31, 2020Tutor
After resetting 8-10 times now, the connection is stable on verison2.3.2.104 thanks for the help
