geomoondog
Feb 15, 2021Aspirant
Netgear XR500 Firmware update V2.3.2.56 and up: Once I install updates I can not play any videos
Netgear XR500 Firmware update V2.3.2.56 and up: Once I install updates I can not play any videos anymore from Infuse on my AppleTV. When I install the V2.3.2.56 it runs fine! Does anyone know why t...
michaelkenward
Feb 16, 2021Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
I will ask the Netgear moderator to move your message.
- geomoondogFeb 16, 2021Aspirant
That would be great! Thanks
- Netduma-FraserFeb 16, 2021NetDuma PartnerI'd recommend upgrading to the very latest beta firmware found here: https://www.dropbox.com/s/4mwe5sx81gsc129/XR500-V2.3.2.114-DumaOS3.0.203.img?dl=0 then do a factory reset and see if it works after that.
