Forzurda
May 13, 2022Aspirant
Netgear xr500 ipv4 seemingly stops working randomly
Heyo, I bought my XR500 a good while ago, but the last few months I've had a really annoying issue where the IPv4 portion of the network, seemingly just dies, and doesn't come back until I reboot the...
Netduma-Fraser
May 13, 2022NetDuma Partner
Could you clarify what you mean exactly? Are you saying the internet completely cuts out? I did the same tracert as you and I had the same results as you where it times out after the ae124 domain - I only have IPv4 and connection is working fine. You cannot always ping/trace a specific IP if they block pinging for example.
- ForzurdaMay 13, 2022Aspirant
Basically when it happens, I can't use anything that is IPv4 only, for example sites like Reddit and Google, which have IPv6 addresses, I can access. But basically everything else like discord and duckduckgo, are inaccessible.
I confirmed this by checking test-ipv6.com, where it would show IPv6 address but no IPv4 address on all my devices, and doing a ping to google DNS would work but not much else.
It could be my ISP, but why I don't think so is because the issue gets resolved when I reboot the router.- Netduma-FraserMay 13, 2022NetDuma PartnerOkay that's interesting, could you reproduce the issue then provide the logs from the System Information page please?
- ForzurdaMay 14, 2022Aspirant
I'm not sure how to reproduce the issue to be honest, from what I know it just happens randomly.
I can provide my full log or wait for it happen again?
