Forzurda
May 13, 2022Aspirant
Netgear xr500 ipv4 seemingly stops working randomly
Heyo, I bought my XR500 a good while ago, but the last few months I've had a really annoying issue where the IPv4 portion of the network, seemingly just dies, and doesn't come back until I reboot the...
Netduma-Fraser
May 13, 2022NetDuma Partner
Could you clarify what you mean exactly? Are you saying the internet completely cuts out? I did the same tracert as you and I had the same results as you where it times out after the ae124 domain - I only have IPv4 and connection is working fine. You cannot always ping/trace a specific IP if they block pinging for example.
Forzurda
Basically when it happens, I can't use anything that is IPv4 only, for example sites like Reddit and Google, which have IPv6 addresses, I can access. But basically everything else like discord and duckduckgo, are inaccessible.
I confirmed this by checking test-ipv6.com, where it would show IPv6 address but no IPv4 address on all my devices, and doing a ping to google DNS would work but not much else.
It could be my ISP, but why I don't think so is because the issue gets resolved when I reboot the router.
- Netduma-FraserMay 13, 2022NetDuma PartnerOkay that's interesting, could you reproduce the issue then provide the logs from the System Information page please?
- ForzurdaMay 14, 2022Aspirant
I'm not sure how to reproduce the issue to be honest, from what I know it just happens randomly.
I can provide my full log or wait for it happen again?- Netduma-FraserMay 14, 2022NetDuma PartnerOkay no worries, if you could wait for it to happen again then grab the logs and let us know the time it happened roughly so we can match that with the logs that would be really helpful
