Vinlie
Mar 30, 2021Tutor
Netgear XR500 Lagging but only during the daytime
My gaming internet connection is mainly solid but suffers from numerous lag spikes but only during the daytime. At nighttime, it's litearlly perfect, not a single lag spike. I've read somewhere that ...
Netduma-Fraser
Mar 30, 2021NetDuma Partner
There is a free WiFi Analyzer on the Microsoft Store for Windows called WiFi Analyzer, you can use that to identify the channels that aren't being used as much. You can then change to those on the WiFi settings of the router and see if that improves it
- VinlieMar 30, 2021Tutor
Thanks for the hasty reply, I'll go test it out later tonight when I'm back home :)
