Solo21
Jun 27, 2020Tutor
Netgear xr500 netduma 3.0
Hi I recently downloaded netduma 3.0 to my xr500 as part of the beta participants. i l updated my router and done a factory reset on thinking that ill reset my settings back to default for the 3.0 and...
- Jun 27, 2020For 3.0 related queries could you post in the beta forum please?
Once there can you access using the LAN IP via a wired PC and see if it prompts you to do the setup wizard please?
Solo21
Jun 27, 2020Tutor
Oh and im on Bt Full fibre to the Home
- Netduma-FraserJun 27, 2020NetDuma PartnerFor 3.0 related queries could you post in the beta forum please?
Once there can you access using the LAN IP via a wired PC and see if it prompts you to do the setup wizard please?- Solo21Jul 02, 2020TutorAhaa Forgot that I had to use ethernet for the setup. Thank you so much, all is well now. I can finally enjoy destroying newbs on apex legends again.đ
- iielmesswavyJul 31, 2020ApprenticeCan I get invited to this forum? It seems like I donât have it yet...
- Netduma-FraserJul 31, 2020NetDuma PartnerHave you signed up for the beta here: http://www.netgearinnovation.com/dumaos-beta/index.html ?
