Solo21
Jun 27, 2020Tutor
Netgear xr500 netduma 3.0
Hi I recently downloaded netduma 3.0 to my xr500 as part of the beta participants. i l updated my router and done a factory reset on thinking that ill reset my settings back to default for the 3.0 and...
- Jun 27, 2020For 3.0 related queries could you post in the beta forum please?
Once there can you access using the LAN IP via a wired PC and see if it prompts you to do the setup wizard please?
Netduma-Fraser
Jun 27, 2020NetDuma Partner
Solo21
Jul 02, 2020Tutor
Ahaa Forgot that I had to use ethernet for the setup. Thank you so much, all is well now. I can finally enjoy destroying newbs on apex legends again.đ
