Djimi
Mar 17, 2018Guide
Netgear XR500 on Plusnet
Hello community, Please help. I've just set up my New Netgear XR500 on Plusnet. Seems to be working but cannot disable the WiFi on the Plusnet router so now have two devices giving out WiFi. Anyone...
Djimi
Mar 17, 2018Guide
I've looked through loads of help things & chatted to someone online but they couldn't help. The plus net 'fix' on their forum is buy a third party modem. Thanks anyway.
BIG_DOG
Mar 17, 2018Luminary
The hauwei openreach modem hg612 if favoured by many as you can buy a hacked 1 for about £30 which allows you to view your line stats. Or just get a. standard openreach modem as it is just plug n play. They are inexpensive and never needs attention once connected.
- DjimiMar 17, 2018GuideThank you. Will take a look.
- KillhippieMar 17, 2018Prodigy
The HG612 is getting a bit long in the tooth but they do work well, I'm on an ECI Cab and my line likes the ECI version better by about 7Mbps, which is a nightmare as it needs a hardware hack for stats. If you do grab a HG612 get a 3B version, the others had issues with overheating, also make sure as BIG_DOG said its been updated to the latest firmware to support G.inp and also so you can get stats off it if you want them.
