Djimi
Mar 17, 2018Guide
Netgear XR500 on Plusnet
Hello community, Please help. I've just set up my New Netgear XR500 on Plusnet. Seems to be working but cannot disable the WiFi on the Plusnet router so now have two devices giving out WiFi. Anyone...
Netduma_Jack
Mar 17, 2018NetDuma Partner
Just to add - I assume you are trying to turn off the WiFi to prevent interference with the XR500? If so, you could try swtiching the plusnet router to something less used like channel 2 and make sure the Xr500 is on a different channel e.g. 11. Then see if the XR500 WiFi is everything you expect. If so, it will save you having to spend £30 or so on a new modem.
