Vinlie
Mar 26, 2021Tutor
Netgear XR500 Pro Gaming Router loses wifi randomly for a few seconds then turns back on
I'm sure you all are tired of hearing problems with routers but heres to hoping you'll help me out with my own dilemma. I purchased the XR500 a couple of months ago as an upgrade to my R7000 in hopes...
- Mar 28, 2021
Got busy for the last few days but it seems like my internet isn't droppin anymore after the update, thanks guys :) hoping I can keep the thread open just in case it starts to drop again tho
Netduma-Liam
Mar 26, 2021NetDuma Partner
Sorry to hear that!
Could you first please try upgrading the the most recent firmware located here:
https://www.dropbox.com/s/l3oeb6dw25ngmwm/XR500-V2.3.2.120.zip?dl=0
I would also suggest that you perform a factory reset after the upgrade to clear any low-level code from the previous firmware.
- VinlieMar 26, 2021Tutor
I'll give it a shot once I get home as well as a 24 hour grace period to see if the latest firmware was the issue. See you then :)
- VinlieMar 28, 2021Tutor
- Netduma-LiamMar 29, 2021NetDuma Partner
That's great to hear, let us know if you need anything else!
