castagnaccio99
Jan 19, 2019Follower
Netgear XR500 problema test upload PS4
Hi, I recently activated a 1GB fiber line with open fiber (city fiber), I connected the open fiber modem to an XR 500 and everything works perfectly, speed Down / UP average 400/200 after several tes...
Jan 19, 2019Guru - Experienced User
The problem is with the PS and not the Router. I Don't put much trust in gaming consoles speed test abilities. Espeically there wireless. If your PC wired speed tests are coming back correctly, then the router and ISP services are working correctly.
I recommend connecting the game console to the router via LAN cable and game with it. Use a wired PC to check speed test integrity as needed.
This maybe a problem at the game console and you would need to contact the consoles Mfr for help and information regarding it.
Netduma_Jack
Jan 21, 2019NetDuma Partner
Exactly as Furry said, speedtest on consoles is not reliable. So trust the results you are getting via speedtest.net through your PC.
