iielmesswavy
Sep 13, 2020Apprentice
Netgear Xr500 Readyshare not recognizing external hard drive
Netgear XR500 Issue- Readyshare not recognizing or not seeing external hard drive. External Hard drive- SPECS *External Hard drive running on NTFS File system* GENERAL Capacity 2 TB (chan...
Netduma-Fraser
Sep 13, 2020NetDuma Partner
Is it one of these supported hard drives? https://kb.netgear.com/18985/Will-my-USB-drive-work-with-ReadySHARE
- iielmesswavySep 13, 2020Apprentice
Technically, yes, it shows WD My Book Essential is supported.
- Netduma-FraserSep 13, 2020NetDuma PartnerI assume you have tried both the available USB ports on the router? Can it be seen by your PC? When you first connected it to the PC did it require drivers/software to be downloaded before you could see it properly?
Yes, I have tried both USB ports. Furthermore, when connected to the pc it did not require any special program to be installed.
